| | | Forums66 Topics128,014 Posts1,055,331 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | Got a 50 1/2 ton panel I'm rebuilding the steering box on. Quick question though, upon removal of the lower worm shaft bearing there was a pressed in retiner. In the new kit there isn't that piece. There are of course new bearings and race, does that new bearing and race just sit at the bottom on top of the worm bearing adjuster and against the worm shaft assembly at the top?Hope this makes sense to someone, thanks | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | The instructions I got with the kit I used said that retainer you are describing was just used during factory assembly and to toss it out. It pulls out with a little persuasion.
Chuck | | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | Thanks, I was able to get the old and bad retainer off. Wanted to make sure I didn't need to find another because nobody has them. Now I know I don't need to worry about it. THANKS! | | |
