0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#663255 07/18/2010 2:42 AM
Looking for help on the '48 clamshell Burb (guide r-13) taillamp. I've had the truck rewired with Classic Harness but didn't have the tail lamp done at that time. The tail light works but cannot figure out the stop lamp. I have four wires to the rear (two purple, white and a reddish if I remember correctly)They are not numbered in the back and I am currently unable to crawl under and look.I know a lot of you guys have used this harness, any suggestions?
briank #663486 07/18/2010 11:28 PM
I will not be near my trucks and/or the Classic Parts (Chevy Duty) instructions for a few weeks. As I recall, the purple wires are for turn signals (non-standard wiring). It is possible to wire it for the single tail lamp - maybe someone near their one-tail/stop-lamp Classic Parts harness installation will post a reply.
Are the purple wires exactly the same (or does one have a ridge or stripe on it)?
Did you try calling Classic Parts Technical Support?
tclederman #663619 07/19/2010 2:30 PM
If I recall they look the same but I have black electrical tape on the one because it's the only hot wire. I think I need to have the hot wire and the white wire ( which I think in the front is connected to the stop lamp switch) wired together at the rear and the other grounded and should work, right? Haven't been able to try that combo yet. Maybe my guy has a wire hooked up wrong in front regarding the purple wires, it seems they should be for the signals though. I'll have to check today
briank #663724 07/19/2010 11:18 PM
dark purple- tail lamps
pink- left turn & brakes on dual taillight application
light purple-right turn & brakes on dual taillight application
white- brakes on single taillight application if on dual taillight application you can use white for backup lamps by putting switch at dash and running jumper to front end of wire.
Many times taillight problems can be eliminated by running ground to each lamp base.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Old Dollar #663728 07/19/2010 11:46 PM
Thanks a lot for that info!!
