0 members (),
81
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | My '71 C10 has turned into a real adventure. I am now down to tune-up stuff, at last. There doesn't seem to be any agreed upon "best" way to run the plug wires. I have the stock "rams horn" manifolds and heat shields, so the wires should come up from the bottom. The previous owner has the wires zip tied together and to the frame to keep them off the exhaust. Since this obviously isn't the best way to go, can any suggest a better or stock way to run the wires? I'm not really into the shiny chrome looms, etc. Thanks in advance for any help.
Les | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | "best" doesn't apply  - originally when the wires came up from the bottom, they're held by clips that attach on the pan bolts, 2 doubles on each side, and 4 slot looms at the back, as well as at back of the intake - these, which usually get lost/tossed when work is done .... later [I thought by the 70's] they ran them over the top with various other loom arrangements Bill | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | There are two 1/4" X 20 drilled and tapped bolt holes in the block, just below the cylinder heads on the older blocks. They were for a set of sheet metal looms that kept the wires off the exhaust after they came through a set of 4-wire looms at the back of the block behind the heads. The tricky part was keeping the wires for the front two cylinders for each side off the exhaust pipe where it attached to the ram's horn manifolds. I believe there might have been a single 2-wire guide attached to one of the oil pan bolts in that area. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All the wire holders are available in a kit from the specialty suppliers. The wires for the front cyls go underneath the engine mounts. You do not have to remove or loosen the mounts. There is enough room to tuck them through even 8 mm. This method takes a little longer to put in the wires but it is factory & looks good. The wires will not getup against the manifolds or pipes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Many thanks to the three of you! I got a set like the ones Bill posted off a junk engine that was in the weeds out behind a friend's shop. They were set up like Jerry said. They were guarded by a mean spirited little copperhead who has since met his maker. I guess we messed up his home when we rolled the block over with the Jeep and a chain. There were only two of the little "2 wire" clips though. The wires on that engine were run through the mounts like Wrenchbender Ret. said.
Again, many thanks.
Les | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | If you haven't picked up wires yet, the unfinished ones may be a bit better to make a clean instal. I always get annoyed with boxed sets that have overly long wires, the excess seems to always get in the way. So it's nice to be able to route them exactly the way you want them, cut & terminate. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Freq,
I always do that sort of thing, cause there "ain't no" universal sets. About all I see around here is MSD and Accel, but I'm sure that there others. I usually go ahead and get the better quality or larger wires. It may not make much of a difference on a stock engine, but I feel better for doing it.
Best wishes,
Les | | |
