3 members (52Carl, Bill Hanlon, klhansen), 92 guests, and 0 robots.
Topics128,113
Posts1,056,614
Members48,450
#663291 07/18/2010 5:36 AM
Anyone have insight on what would be a modern replacement for my existing 3100 rear axle? Not really concerned with ratio, as my drives are stop light to stop light for the most part on a 350 SBC/ 350TH
Why not rebuild the old one? Just curious.
Avette4me #663376 07/18/2010 3:08 PM
Riding in the Passing Lane
I don't understand why you want to change to a "modern" rear end if you don't need to change ratio's. What wheel bolt patern do you want to use. The Camero/firebird rears are good replacement but have 5 bolt small bolt paterns. The Blazer rear ends have the 6 hole paterns. Any thing you use will have to be modified to fit.
1972 Chevy c10 Cheyenne Super
I was thinking that rebuild cost might be in excess of what I can pick up a good used rear axle for, thus the question. No desire to change the bolt pattern, as I like the 6 lug design.
Any suggestions on what year Blazer will work? I am not looking to have to change and modify width, though i expect some changes to mounting might be required. Would be nice to find a posi or locker though...
I have a U bolt kit to sell if you make the swap. I had a locker from a blazer (late '80's) bought, but found it to be about an 1-1/4" too wide. The backing plates measured the same, but the drums were wider so I sold it.
Just an FYI, I ended up buying a 3.38 with a complete rebuild kit from Patricks. It was under $600.00.
Avette4me #663402 07/18/2010 4:57 PM
Originally Posted by Avette4me
... but found it to be about an 1-1/4" too wide. The backing plates measured the same, but the drums were wider so I sold it.
That only moves each wheel out 5/8", I can't see that as a deal breaker?
Unless I'm missing something it sounds like a good swap to me.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #663406 07/18/2010 5:21 PM
Grigg
I load this truck a bit heavy on occasion and the tires would have rubbed.
Avette4me #663416 07/18/2010 6:05 PM
You can buy a used center section reasonable & change it in a couple of hours.
The original rear end in those are about as stout as any out there.
