2 members (Southerntruck, Hush),
150
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I recently picked up an intake manifold that had a raised buss on it, That I thought was for mounting a horn. Now that I have it in hand there are no mounting holes for the horn. Did the 235 intakes come in a version that had no holes and need drilled, or with cast holes for the horn, or am I just plain lost, or do I need to keep looking for the right intake manifold? The 52 has rams horn hi and low horns, but I like the look of the single horn shaped horn. Any sugestions would be appreciated.Jimmie. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From 1954 and onwards the horn was not mounted on the 235/261 intake manifold.
What year intake manifold do you have?
The dual-horn option/accessory was not usually mounted on the intake manifold; but, I would guess that in 1953 and earlier years that the intake would most likely still have had the holes for the horns. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hi Tim, Thanks for responding. The motor is a 56 235 I Was given an intake from an unknown year. From the info you gave me I suspect it is from a 54. I have the duel horns from what I think is the original 56 motor That replaced the 216 that was in the truck. It looks like I will just have to keep my eyes peeled for a 53 and earlier manifold. Thanks again, Jimmie. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Jimmie - if the horns came with the engine, the 55.2-59 trucks mounted the horns on each side of the rad on the core support, if they had both, otherwise one on drivers side core support
Bill | | |
