5 members (klhansen, 2-Ton, Gray_Ghost, mason86, Charles in CA), 100 guests, and 1 robot.
Topics128,069
Posts1,055,886
Members48,428
#661823 07/12/2010 5:19 PM
I've always wondered about the radiator in my ole 45 2-ton. The overflow tube is at the top of the tank and not on the fill opening. I wonder about the cap size, and have been running a 0 pressure type. The original radiator was a honeycomb type, but got "fixed" so much that I had the cooling tubes replaced. It cools fine. Just wondered what other folks know about these things. Can I use a pressure cap on it?(4lbs)
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
rads were 0 pressure into the 50's, 4# would be possible with a well rebuilt rad, but you'd have to move the overflow into the neck or it'll never build any pressure - OTOH, the advantage of the pressurizing is to raise the boiling point and it shouldn't ever run hot enough to require that if all is well
Thanks Bill,
I talked to a rad. guy and he said the same thing. So will keep on truckin, the same ole way, keep my eye on the guage.
