10 members (klhansen, papas52, baldeagle, 1955 1 Series, KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie),
178
Mod | | | Forums66 Topics128,165 Posts1,056,999 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I have HF HVLP kit, it was good for epoxy primer and even for top coat with 1.4 tip. I hated it for 2k Primer with 1.8 tip. It was not doing good at all and tool very long time. I need to buy a gun for primer gun very urgently.
Any inputs/thoughts appreciated
Ganesh | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I did all my primer work with this $20 gun from HF. Color was all painted with this kit. | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Thanks Fried Green, ok so that $20 bucks worked good for primer, I have the same kit for color and it is not that bad when I tried color yesterday on Firewall. That kit didnot work good for primer though
Ganesh | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I also found that air pressure needed to be at or slightly below the mfg. recommendations. You will have to play with it some because the air is much thinner up here. You will also need a water trap in the Va. humidity. | | |
