1 members (Hanks custodian),
122
Mod | | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66144 09/21/2006 1:19 AM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | When running fuel lines to now two single barrel small throated carbs, does one use 1/4 inch or 3/8 inch lines? | | |
#66145 09/21/2006 2:15 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Use whatever size that came on it originally. The two carbs won't use much more fuel and the same size line probably goes from the fuel tank to the fuel pump anyway. | | |
#66146 09/21/2006 5:37 AM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Let me rephase my original line. Does a lower pressure flow work better than a higher pressure flow to the carbs? 1/4 inch should produce a higher fuel pressure after the fuel pump than 3/8.. If post pump line is 3/8 inch then necks down to 1/4 inch to carbs; would that make any difference? | | |
#66147 09/21/2006 5:38 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Think the original is 5/16" line. If you had to choose between the 1/4" and 3/8", I would go with the 3/8". It won't appear to be any larger to anyone looking at it and certainly is easier to find than 5/16". If you use 1/4", it will look too small and will probably be to small to supply enough fuel for both carbs. Just my 2 sense. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#66148 09/21/2006 2:41 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rattletrap52,
Pipe size has no bearing on pressure, only volume.
I wouldn't be concerned with volume as each carburetor has a giant "well" that would never be drained regardless of a heavy foot.
I agree with 6cylinder, it's all about style points and parts availability. The stock 5/16 line would look 'right' to me.
Stuart | | |
#66149 09/21/2006 5:13 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Actually, there are some issues to think about.
A small tube will have slightly (but measurable) LOWER pressure and significantly less volume.
The important issue is velocity of the fuel in the lines.
Too large a tube, and the velocity is very low (larger volume). The fuel sits in the tube and is heated by the surrounding heat sources. This can contribute to vapor lock during periods of high ambient temperature and low fuel useage (stop and go city traffic).
Too small a tube, and the velocity is very high (due to much less volume), which can cause unpredictable operation of the float in the carburetor. A side note to this issue is the Q-Jets of 1967 and 1968. The float position in the Q-Jet was changed in 1969 such that a "windowed" fuel valve seat could be used for higher volume fuel flow necessary for high performance engines. Seemed the fuel coming from the window sprayed on the float, causing a flooding condition. The repositioned float allowed for use of the window.
We would suggest 5/16 for the typical stovebolt.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#66150 09/22/2006 2:18 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I used 5/16". You can find steel line sizes from 3/16"-1/2" at any parts store.
Bill Burmeister | | |
#66151 09/22/2006 3:48 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Longbox55,where did you get your fuel log ? I'm thinking of using one also. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#66152 09/22/2006 3:59 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | | | |
#66153 09/22/2006 4:07 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Those are cool,but i'll pass on the skulls . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#66154 09/22/2006 5:06 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | bowtietim, the fuel log came from Mooneyes, it can't be seen in my pix too well, but it has "Moon" cast on the top of it. The regulator cover came from them, too. No regulator under it, however. It covers the relay for the overdrive.
#66155 09/22/2006 6:47 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | In my business, there is a huge difference between 3/16", 1/4", 5/16" and 3/8". Those are the sizes we use. For a larger inner diameter, it takes significantly less pressure to move fluid at a specific velocity. The restriction on 3/16" is approximately 2 lbs per ft. For 5/16 it is about 1/2 lb per foot. We balance restriction with pressure to make draught beer pour well. The moral of the story is - size matters! | | |
