1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Anyone out there know what the correct size freeze plug is supposed to be in the front of the block, just below the water pump ? Mine disappeared somewhere! Thanks AM | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Well, you don't say what year engine,but likely it's 2" steel.
Drew
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | I guess I should have said that from the outset ! Its a '54 engine, the hole looks like it measures about 1.825", but It's hard to tell looking at it, if its the hole I'm measuring or whats left of the outside rim of the plug, is there normally a step there or is it just machined smooth all the way through the block ? I don't want to beat on the step if its actually part if the block! Thanks AM
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Just getting back to stovebolt. It's stepped.
Drew
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Well its not a 2" plug, anyone else want to guess ? Think I'm just going to spin a couple up on the lathe and trial and error fit! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Get the whole set from Chevsofthe40s. Then you know you will have the right one and you might consider replacing all you can at the same time. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | just head to yer FLAPS for 3 or 4, get one each of close sizes, there's only a certain number of possibilities and they're cheap ... use the one that fits properly
Bill | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | I did go to my local FLAPS and brought home one of each size in their trays that were close to it, none of them fit. And I am going to order a whole set to replace them all during the winter, just don't want to get into that big a job during summer driving time! As a last resort, my next step would be a rubber expanding plug, But I'm not a fan of Temporary fixes, besides I'm pretty sure the brass one I spun up this morning will work just fine. I was just hoping somebody off the top of their head knew what size it was supposed to be. Thanks! | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Usually when one goes bad, one or more of them ain't far behind in my experiences. Get a brass set like T'mater recommends. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If You can't find one at flaps, if You have an engine rebuilders shop close by go there they would have them and know the size,I got all of mine from a local rebuilders ,he cleaned the block and the bare head for Me and I had Him install new cam bearings so when I was there I got the freeze plugs from Him,he had a book that had all the sizes in it and He had every size youl'd ever want.
Pete | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Thats a real good idea, never even thought of that, thanks! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You didn't say why 2" steel plug didn't fit. Keep in mind that a steel plug gets dimpled in the center to expand its edges for a tight fit.
Drew
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Drew, the hole is only 1.825 max. No amount of persuasion would make a 2" plug fit in that hole. There is no way a steel or brass plug could distort .175" crush. Thanks anyways Andy | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Andy, I just measured the ID of the front hole of a 1954 block and it is 1.996 to 2.000". The ID after the step is about 1.85". The Master Parts Manual shows the same size for all 37-57 sixes. Is the remnants of an old plug still in the hole? Hoyt | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Hi Hoyt, Yes the first step is 2" but the freeze plug goes in the machined bore further in, which is the 1.85 bore, the 2" step is far too shallow for it to hold the plug. I did at first think it was the outer diameter of an old plug still stuck in there, but after cleaning and sanding it off it looks like cast iron to me. I'm not going to bash on it in the event it is the block I'm bashing on. Going to work on it Saturday, so will keep ya posted, thanks Andy | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Andy,
I have used the dished core plugs for the front and rear holes, not the cup shaped plugs. You want to install them with the dished part rounded OUTWARD, and the plug will just about drop into the boss in the block. Then you center a large drift on the plug and give it a coupla taps with a hammer to flatten it out slightly, which makes it seal in the block, as Drew mentioned above. Oh, and I always use a bit of the old-style Permatex sealer on them too.
Hoyt | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Really ? Am I looking for the wrong kind of plug? I've never used anything other than the cup type, didn't know there was another type? If thats the case, then I owe an apology to the people here who are trying to steer me straight and I didn't understand why they didn't get it! Its me that doesn't get it! Haa!! Haa!! Is the dish type a common plug from FLAPS, they didn't show me any other types other than the cup type. Thanks! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is definitely a dished plug. It does sit against the step and I would suggest some locktite to seal it up. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Yes, the flat plug is pretty common, but you'll need to find a FLAPS counter man who actually needs to shave more than once a week. One with a little gray around the temples is even better. Clean the shallow groove thoroughly, maybe with a rotary wire brush in a drill motor, then paint a little brush-on Permatex sealer into the groove. Put the dished plug into the groove with the convex side out, and give it a firm tap in the center with a 3-lb. BFH. The dish will collapse slightly and seal the edge of the plug against the block. Jerry
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Thanks guys, I really do owe an apology to DrewP who tried to send me down the right road but guess I had my head up my ***! Well the 20year old girl at the FLAPS counter did have that kind of blank look on her face when I asked for the freeze plug..... You know that little voice in your head that says you wasting your time in this store ? Guess I should have listened to it huh ?
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | I've ordered a set from chevsofthe40's as FriedGreenTmater suggested earlier, pretty much done beating my head against the wall with the parts suppliers around here, clearly no old gray haired counter people left at the NAPA stores around here! Will just wait for them to get here I guess, of course its about 90 degrees here today so not a good day to tool around in the truck anyways! Thanks everyone for your help! Andy | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I was loking for one of those plugs, I went into a GM dealership to confirm that they would laugh at me because it was more than 10 years old! To my amazement, the guy looked through some catalogs and then sent me down the road to a jobber. The jobber had them in stock. I am ashamed to admit I don't know what a jobber really is or how they fit into the chain. Anyhow, I bought several and that was good because six months later I had to replace the one in the rear. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks guys, I really do owe an apology to DrewP who tried to send me down the right road but guess I had my head up my ***! Well the 20year old girl at the FLAPS counter did have that kind of blank look on her face when I asked for the freeze plug..... You know that little voice in your head that says you wasting your time in this store ? Guess I should have listened to it huh ?  Hah.No apologies allowed on Stovebolt for seeking advice when you're not sure. Heaven knows,if that were the case, I'd have my own "Mia Culpa Forum'!
Drew
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Yes but hopefully with time, I'll soak up enough information here and actually heed when somebody gives me good advice instead of jumping to quick assumptions! Although I do feel somewhat proud of making a posting run for three pages about a freeze plug!!!Haa!! Haa!! :):):) Thanks Drew. | | |
