8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian), 66 guests, and 5 robots.
Topics128,065
Posts1,055,868
Members48,428
#66052 09/19/2006 9:39 PM
Can anyone out there tell me when or what year GMC changed from a 4 bolt flywheel to a 6 bolt flywheel and when did Chevy change from a 4 bolt to 6 bolt? And the difference between a 153 tooth flywheel and a 168 tooth flywheel.
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
#66053 09/19/2006 11:30 PM
I've got three different Chevrolet flywheels on hand and one on my truck and all of them are 6 bolt flywheels. At least one of them is a 139 tooth flywheel which is for use with a 6 volt starter. The others are 168 tooth flywheels and they are for use with 12 volt starters. The crank on my old 52 model 216 was also set up for a 6 bolt flywheel.
6 volt and 12 volt starters are kind of hard to tell apart when looking at the teeth, but they are definitely different.
GMC may be, and probably is, a different situation, especially the earlier years, 30's and 40's.
Joe smile
GMC went to 6 bolt beginning with the '54 248. They and '55 1st series flywheels are 139 tooth and use a 6V starter. If you put a later 248, 270 or 302 in a 6V truck you'll need to find one of these flywheels or convert to 12V because they have 168 tooth flywheels.
Never heard of a 153 tooth flywheel. Are you sure it's GM?
#66055 09/21/2006 12:14 AM
The 139 tooth ring gear will fit on a 168 tooth flywheel if you have a machine shop turn the flywheel down to fit the gear. However, the converse is not true.
Paint & Body Shop moderator
Hi All,
This came up because my 270 uses a 4 bolt fly wheel and I was trying to find a larger clutch and fly wheel setup. My 270 has the 9 1/8 inch clutch.
I wanted an 11 inch clutch for towing. Then someone came up with a 4 bolt, 13 inch clutch and flywheel out of a school bus...weeeeeee, I bought it.
Then I found a 4 bolt, 11 inch clutch and fly wheel, which I also bought.
Then I found a 11 clutch and flywheel for my 248 which has a 6 bolt crank.
I only have one chevrolet 4 bolt flywheel. It came off a 1937 216 in a 1941 chevy 1/2 ton truck. Other than that all the Chevrolet flywheels I have are 6 bolt ranging from 1946-1954.
I'm a little lax on GMC info.
Jeff
My 1953 Chevrolet
1947.1 Gallery
