3 members (Shaffer's1950, Bill Hanlon, Hotrod Lincoln), 143 guests, and 3 robots.
Topics128,190
Posts1,057,339
Members48,469
Two of the three metal tabs that hold the turn signal assembly in place are broken off on my mast jacket. I haven't found one to replace it so I'm going with option 2--which is try to make new tabs to weld back on. I found one of the tabs that broke off, but I'm still missing that third piece. Any pictures/measurements of those tabs would be much appreciated.
This is for a 1966 with a three speed on the column.
Here are some pictures of my mast jacket: http://s809.photobucket.com/albums/zz19/wilkinst/1966%20Chevrolet%20K20/
Trey Wilkins
1950 Chevrolet 3100 Five Window
1954 Chevrolet 4100 Dumptruck (Sold)
1957 Chevrolet 6400 Dumptruck
1966 Chevrolet K20 Longbed Fleetside
1966 Chevrolet C60 Grain Truck (Sold)
More pix on Photobucket
I had a similar problem with my 1965. Might I suggest that you call Tony Smith at 4-5-6-trucks 913-207-7789? I called him and after some discussion bought a replacement upper bonnet. Tony has great prices on original GM used parts and is very knowledgeable. If you haven't used him as a resource give him a try.
Here's what I went through http://67-72chevytrucks.com/vboard/showthread.php?t=399139&highlight=lower+bearing
Thanks for the tip. I called Tony and he had one! Saved me some work!
Trey Wilkins
Glad I could help. thumbs_up
