3 members (Cosmo, JW51, 1 invisible), 131 guests, and 2 robots.
Topics128,080
Posts1,055,956
Members48,430
#659927 07/05/2010 8:15 PM
Anybody know if 1954 1 ton spindles are reproduced or NOS anywhere? I found out while disassembling mine today that they are both shot. The drivers side was galled severly and the passenger side had the grease fitting brazed into place.
Bruce
My Trucks
Stuff I Collect
They should not be hard to find used in reasonable condition. You should be able to use any 1-ton spindle from a Bendix type truck 3/4- to light 1-1/2 starting about '52 (need to confirm that with bearing and seal number lookups) through the '55 1st trucks.
OldSub #659985 07/06/2010 2:14 AM
I have 2 new old stock spindles I bought just in case. You can have them for what I gave for them which was under 100 bucks.
OldSub #659988 07/06/2010 2:18 AM
I have one more 1 ton front axle to dismantle tomorrow so I'll know then if I need to keep looking.
Bruce
My Trucks
Stuff I Collect
I lucked out and now have two good spindles off my other axle. I have to say the king pins did NOT want to come out!! The ones on the first axle just tapped out nicely. On to the next chore.
Bruce
My Trucks
Stuff I Collect
Moderated by  Dusty53
