| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Anybody know if 1954 1 ton spindles are reproduced or NOS anywhere? I found out while disassembling mine today that they are both shot. The drivers side was galled severly and the passenger side had the grease fitting brazed into place.
Bruce | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | They should not be hard to find used in reasonable condition. You should be able to use any 1-ton spindle from a Bendix type truck 3/4- to light 1-1/2 starting about '52 (need to confirm that with bearing and seal number lookups) through the '55 1st trucks.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2009 Posts: 7 New Guy | | New Guy Joined: Mar 2009 Posts: 7 | I have 2 new old stock spindles I bought just in case. You can have them for what I gave for them which was under 100 bucks. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I have one more 1 ton front axle to dismantle tomorrow so I'll know then if I need to keep looking.
Bruce | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I lucked out and now have two good spindles off my other axle. I have to say the king pins did NOT want to come out!! The ones on the first axle just tapped out nicely. On to the next chore.
Bruce | | |
