10 members (sron48, cmayna, Scott, 48jim1ton, frogfarmer, Wayne67vert, Wally / Montana, gswbbc, Gdads51, panel fan), 129 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#651238 05/31/2010 10:53 PM
Apprentice
Apprentice
Iam a new guy to your site I mostly work on 67-72 chevys but I came across this 65 GMC and had to have it. They told me it was a 1/2 ton but it has leaf springs and six lugs.Can anyone help me out here
thanks
1965 GMC 1/2-Ton Short Box Stepside
More pix on Photobucket
HeavyChevys #651243 05/31/2010 11:20 PM
when searching for a frame for my 65 4x4 project I ran into a gmc frame that was 2 wheel drive with leafs. the owner said that it was an option back then. other than that only 4x4 came with leafs. half tons had 6 lugs,
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
Curt Guild #651247 05/31/2010 11:27 PM
Apprentice
Apprentice
thanks curt
HeavyChevys #651255 06/01/2010 12:04 AM
'60-'66 Chevy light-duty trucks had trailing arms/coils...GMC trucks of the same years had leafs.
Apprentice
Apprentice
thanks tony
HeavyChevys #651274 06/01/2010 12:55 AM
Hi, guys.
I'm trying really hard to get over my ignorance regarding these trucks! Once again, here's another chance for you guys to help.
Tony, you say that the Chevies had trailing arms and coils while the GMCs had leafs.
So I found out what a leaf was:
http://www.team-bhp.com/forum/attac...pension-modification-okay-leafspring.gif
Not sure about the trailing arm and coil. Is it what's pictured here running along either side of the drive shaft:
http://www.customclassictrucks.com/techarticles/0702ct_1964_chevy_stepside_pickup/photo_03.html
If the GMCs don't have these arms, they would have more room for an S10-style long skinny gas tank beside the drive shaft. Right?
Am I right that the GMCs don't have these arms, or am I still confused?
Thanks.
Steve.
NewAtThis #651348 06/01/2010 4:54 AM
Yes, that is what is pictured in the 2nd link.
I am not one to suggest putting a fuel cell between the frame rail and the drive shaft.
You are correct, '60-'66 GMC light-duty trucks did not have trailing arms.
Thanks, 4-5-6. At least that gives me another option for gas tanks.
I have a gas tank placement thread on this forum. I'll transfer this discussion over there.
Thanks again!
Steve.
HeavyChevys #659940 07/05/2010 9:43 PM
read somewhere, I thought on this forum, that Chevys came stock with coils and leafs were an option. GMCs came with leafs as standard and coil could be had as an option. I have leafs on my C10 and it rides great. Yes it looks like there is enough room for a tank inside the frame.
taclem
