| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 104 | About 3 weeks ago my work truck (a F#%d) wouldn't start. The battery was dead, so I took the battery out of my 53 to get it started. Since my 53 is on jack stands while I'm working on the steering, I set the battery on the garage floor. Today I decided to start my 53 for a cruise around the block. I put the battery back in it and it was dead. I tried charging it and it won't hold a charge. Did leaving it on the garage floor for only 3 weeks kill it? I always thought that was an old wives tale about not setting a battery on a concrete floor. The battery is only 1 year old. Any thought's on this? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no the concrete floor can't do anything thru the thick plastic case - not recharging it full after the jump might have contributed tho, batteries do NOT like sitting partially discharged
Bill | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | How are you going about trying to charge the battery? One that's really badly discharged will get a condition called "sulfation" where the lead sulfate that forms on the cell plates as the battery discharges forms stable crystals that are very hard to dissolve. Charge it at least overnight at a slow rate, 5 to 10amps, then comnpletely discharge it by connecting something like a headlight bulb. Diuscharge and recharge several times, and the battery will begin to recover. Check the acid with a hydrometer to see how well it's taking a charge. Full charge specific gravity is between 1.265 and 1.300. Jerry
| | | | | Joined: Nov 2008 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 104 | Thanks for the info, guys. I will try what you said to do, Jerry. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Might want to invest in one of these battery tender . I have them on everything because there is nothing more frustrating than wanting to ride/drive something or use the tractor and it won't freaking start. Check Amazon and other websites like ebay for best pricing. | | |
