0 members (),
94
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 12 New Guy | | New Guy Joined: Mar 2010 Posts: 12 | I have a '50 3100. I just got it on the road a few weeks ago. On the initial test drive I noticed that I had a bad vibration while engine braking. After inspecting the driveline I noticed that the threaded collar that secures the torque tube to the ball housing was completely backed off. I cleaned the dirt out of the threads on the ball housing and threaded the collar on as far as i could get it. This semed to remove all play between the tube and the ball housing. After a few drives (about 40miles worth) I noticed that the vibration had returned. I inspected the collar and made sure that is was still tight, it was. I did notice that ther play between the ball housing and the torque tube had returned. Is this play normal? I would assume that there should be some sort of packing between the tube and the housing. Any help or pictures would be appreciated. Thanks, Ken | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ...its been a many years time since I had my 50. I don't think just tightening the collar will help on the vibration. Pull the collar back and check the joints and make sure all is well. | | | | | Joined: Mar 2010 Posts: 12 New Guy | | New Guy Joined: Mar 2010 Posts: 12 | By checking the joints I assume you mean the front universal joint? Could the issue be a worn out front torque tube bushing?
