| | | Forums66 Topics128,191 Posts1,057,224 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 40 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 40 | Two of the three metal tabs that hold the turn signal assembly in place are broken off on my mast jacket. I haven't found one to replace it so I'm going with option 2--which is try to make new tabs to weld back on. I found one of the tabs that broke off, but I'm still missing that third piece. Any pictures/measurements of those tabs would be much appreciated. This is for a 1966 with a three speed on the column. Here are some pictures of my mast jacket: http://s809.photobucket.com/albums/zz19/wilkinst/1966%20Chevrolet%20K20/Thanks
Trey Wilkins -------- 1950 Chevrolet 3100 Five Window1954 Chevrolet 4100 Dumptruck (Sold)1957 Chevrolet 6400 Dumptruck1966 Chevrolet K20 Longbed Fleetside1966 Chevrolet C60 Grain Truck (Sold)In the Stovebolt GalleryMore pix on Photobucket | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I had a similar problem with my 1965. Might I suggest that you call Tony Smith at 4-5-6-trucks 913-207-7789? I called him and after some discussion bought a replacement upper bonnet. Tony has great prices on original GM used parts and is very knowledgeable. If you haven't used him as a resource give him a try. Here's what I went through http://67-72chevytrucks.com/vboard/showthread.php?t=399139&highlight=lower+bearing | | | | | Joined: Dec 2008 Posts: 40 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 40 | Thanks for the tip. I called Tony and he had one! Saved me some work!
Trey Wilkins -------- 1950 Chevrolet 3100 Five Window1954 Chevrolet 4100 Dumptruck (Sold)1957 Chevrolet 6400 Dumptruck1966 Chevrolet K20 Longbed Fleetside1966 Chevrolet C60 Grain Truck (Sold)In the Stovebolt GalleryMore pix on Photobucket | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Glad I could help.
