1 members (homer52),
117
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 13 New Guy | | New Guy Joined: May 2010 Posts: 13 | My cowl vent seens to dump rain. Is something missing? | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Most likely its the drain hose? If not maybe the vent seal? | | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Years ago I had a '54 that had the same problem. The edge of cowl vent has a little gutter around the opening which drains the water to the hose going through the firewall. The gutter on my truck was rusted out so I removed the air scoop the opens and closes and repaired the gutter with fiber glass and put the scoop back in. It worked pretty well from what I remember. That was in 1978 or so. I don't remember how difficult it was to remove the scoop. Jacques
Union, Justice and Confidence
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | What the two above said. Hose or seal or both.
