Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Ponchogl, 1955 1 Series, homer52), 113 guests, and 3 robots.
Topics128,283
Posts1,058,505
Members48,490
My cowl vent seens to dump rain. Is something missing?
Y
Y Offline
Most likely its the drain hose? If not maybe the vent seal?
Years ago I had a '54 that had the same problem. The edge of cowl vent has a little gutter around the opening which drains the water to the hose going through the firewall. The gutter on my truck was rusted out so I removed the air scoop the opens and closes and repaired the gutter with fiber glass and put the scoop back in. It worked pretty well from what I remember. That was in 1978 or so. I don't remember how difficult it was to remove the scoop.
Jacques
Union, Justice and Confidence
Ex Hall Monitor
Ex Hall Monitor
What the two above said. Hose or seal or both.
