1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2010 Posts: 49 | I have these hourglass looking screws all over my 50 GMC PU. What kind of funny screwdriver am I looking for? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Kinda hard to search when you don't know what you're searching for eh? They are called clutch heads. Napa should have the drivers. | | | | | Joined: Jun 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2010 Posts: 49 | Dutch heads, got it. Thanks. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You also need to get your glasses checked. That says c l u t c h. | | | | | Joined: Jun 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2010 Posts: 49 | It does, saved me some searious confusion.. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | You also need to get your glasses checked. That says c l u t c h. Wow, he's new to this. Why make it personal? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't believe he took it personal. Why should you? There's no reason to. | | | | | Joined: Jun 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2010 Posts: 49 | I think it was the font that caused the confusion, no offence taken. Thanks for the reply. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | This is one subject that has really been kicked around here.Anyone starting to work on an old Chevy truck,should invest in a good set of clutchhead drivers.They are not that expensive,most of the parts houses have a set for under $20.00 I am old enough that I remember the clutchhead screws,my first purchase was a single driver at the local NAPA Parts store.Later on I ordered a set from Chevy Duty,which has went thru a name change since then.
| | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | http://www.classicparts.com/1947-66-Clutch-Head-Screwdriver-Set/productinfo/98%2D001/
20 bucks, thatz all you need
Ganesh | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You can drill off the heads and remove them with visegrips, too. This saves time when the head strips out.
I have no use for clutch/dutch head screws
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | SNAP-ON CLUTCH HEAD BITS , My favorite !
There great in a drill ,1/4 ratchet and apex screwdriver handle.Life time warranty about $2.55 each.part numbers are SDM242G SDM243G SDM244G SDM245G SDM246G Hope this can help. | | |
