1 members (Ridgeback), 89 guests, and 1 robot.
Topics128,264
Posts1,058,350
Members48,485
#65918 09/17/2006 9:17 PM
Apprentice
Apprentice
My driver's side front leaf spring is loose at the back end.
The rear c clamp broke and the springs are jammed against the hangers base.
The spring does not look broken but I am not sure.
Can this mess be fixed with out removing the springs ?
Thanks, Kelly
53 3100
http://www.cravy.com/53-3100/LadyAfterRats.jpg
#65919 09/18/2006 1:17 AM
Are you refering to the small clamps that hold the springs in line? They can be replaced but something a spring shop would have to do I would think. Is this problem affecting your ride or making noise? If there is nothing else visibly broken then you should be okay.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#65920 09/18/2006 3:46 PM
Apprentice
Apprentice
It is not safe as is, even turning in the drive way may cause the spring to shift and fall off the edge of the hanger.
Can I lift the frame off the spring and put it back where it belongs?
I think the three leafs at the broken c clamp can be temporally pulled back together with a pulley puller.
Thanks, Kelly
53 3100
#65921 09/18/2006 5:25 PM
Kelly,
You are right it is not safe if it is falling off the rear hanger.
Sounds like the spring has worn through.
Take off the "spring eye bolt" nut and washer and then remove the bolt. The bolt is threaded into the hanger. There is supposed to be a bushing in the "spring eye".
Also, if one side is worn, then chances are the other side is too.
-Tom
1950 Chevy 3100 w/ 1956 235
