| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 33 | Well I'm finally back to my 49 truck project some years later. Quite some time ago I managed to get the truck painted and engine rebuilt. The interior of the truck is stripped of gauges and a new wiring harness is waiting to be installed. I would like to get the truck running so that I could move it around. I have identified the engine harness and where all the wire go. Beyond that it's still a work in progress. My question is what connections do I need in order to start the engine and charge the battery? Can I achieve getting it to a running state without gauges? Thanks Steve | | | | | Joined: Dec 2006 Posts: 8 New Guy | | New Guy Joined: Dec 2006 Posts: 8 | You need power to the coil and to the starter. I assume you still have the foot starter. If you connect the battery to the starter, and run a jumper to the coil the motor will run if all the other ignition wires to the plugs are in and the coil is connected to the distributor. This will not charge the battery, but you should have enough in the battery to move the rig around. To shut off remove the jumper to the coil.
lg no neat sig line | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes as larry says you can, use the ignition switch for your terminations, just lay it on the seat on something and use the key if you want. Shut it off from inside the cab. Disconnect the battery before you go in the house though. No you don't need any gauges.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | True,you don't need to connect the gauges. But,I would remember to plug the oil pressure line hole! Guess how I know. :mad:
Drew
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | DrewP,
I found about that paying attention to the oil line is really important, especially with new carpets!
Les | | |
