| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I have to replace the wheel studs on one of my front drums, (long story and it makes me look stupid). the local NAPA has studs with the right thread and length but the spline is shorter than the old ones. Are these OK to use? Also, How tight should the lug nuts be? Should I use a torque wrench? (I don't want to replace another wheel) Thanks in advance. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Yes you should torque your lug nuts. Finding the value to use is problematic though. Here are some general recommendations stolen from another website:
Lug Size Ft/Lbs Torque 7/16" 55-65 1/2" 75-85 9/16" 95-115 5/8" 135-145 12mm 72-80 14mm 85-95 IMPORTANT NOTICE: As with all types of wheels retorque lug nuts after the first 25 miles & at 100 mile intervals until lug torque is maintained. Note: Always refer to Owner's Manual for proper factory specifications that take precedence over the listed recommendations. | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | Thanks that info will be helpful once I start putting this back together (I wish I asked earlier). How about the NAPA studs? Will these work? Or should I keep looking? | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | Anyone out there got an answer on these? | | | | | Joined: Nov 2005 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 49 | I have used the NAPA ones with no problems.
Brian | | |
