2 members (66flea, Bucker),
81
Mod | | | Forums66 Topics128,265 Posts1,058,363 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65886 09/17/2006 3:37 AM | Joined: May 2003 Posts: 187 'Bolter | | 'Bolter Joined: May 2003 Posts: 187 | The "3 on the tree" gearshift on my 52 3100 rattles quite a bit. It seems to be worn where the shift lever connects to the rod that runs down the steering column. How can I remove the lever? Can you buy parts for whatever is worn in there? What are the parts called?
My dad always told me, "Don't force it, get a bigger hammer".
#65887 09/17/2006 6:41 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | There are two spring loaded pins that hold the lever onto the column. The actual shift lever rod has a ball on the end that fits inside the shift lever, maybe that's where the rattle comes from. Lots of parts on an old truck are worn so chasing rattles might be a full time job. | | |
#65888 09/17/2006 6:56 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yer lookin for "Shift lever retaining pins, spring and rubber bushings" here , and maybe even the mounting piece that screws to the column Bill | | |
#65889 09/18/2006 10:08 PM | Joined: May 2003 Posts: 187 'Bolter | | 'Bolter Joined: May 2003 Posts: 187 | Thanks for the info, guys. You're right about chasing the rattles. For some reason, this one bothers me - maybe because it's right under my nose.
#65890 09/19/2006 4:32 AM | Joined: Apr 2004 Posts: 42 Apprentice | | Apprentice Joined: Apr 2004 Posts: 42 | Try to get by with out the Gear shift collar new ones want fit right & your old one may be ok also the two bolts that hold it on are a rare size do not lose them. Thanks, Kelly 53 3100 http://www.cravy.com/53-3100/LadyAfterRats.jpg | | |
