1 members (papas52),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,542 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 5 New Guy | | New Guy Joined: Aug 2009 Posts: 5 | Does anyone know where to locate parts for a 46 2-ton front axle? - king pin set, brake springs, ball joints, etc. I called all of the internet places for Art Deco Chevys and non of them could help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy kbm, welcome, I think your kingpin kit is Moog 8336B, pin dimensions are 1.109" X 6.812", my brake book doesn't list spring kits back that far, but if you give me some dimensions, there are lots of springs from that far back still available, hope that helps. | | | | | Joined: Aug 2009 Posts: 5 New Guy | | New Guy Joined: Aug 2009 Posts: 5 | I just miked one of the pins - 1.119" x roughly 6-5/16" long...I'll take your advice and check Moog in the meantime. Considering all of this I am prepared to turn and grind new pins....but I would prefer not to even thought it would be fun and I would have to buy more toys for the job. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy kbm, it sounds like you have the lighter front axle, but it also sounds like your pins are already .010" oversize. you may be able to find and oversize set, the Moog number for a standard set is 8343B. It is great that you have the ability to make your own. I did check Rock Auto and they still list the 8343B, hope that helps. | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I have a replacement set of king pins for that truck but they are standard size. 1.109" [email protected] | | |
