0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#658609 06/30/2010 6:27 PM
I've got the driveshaft style parking brake on my '59 3/4 ton with the lever attached to the side of the transmission coming up through the floor next to the shift lever. I took the floor cover off to replace the rusty screws and paint it, etc. The parking lever had this rectangular rubber boot going down through the floor, retained by a metal frame. It was brittle and shot of course. My problem is I can't seem to find a replacement. The ones from the AD trucks are too small and shaped wrong. The vendors all sell a foam donut that fits around the handle fine, but doesn't fill the hole so there will be gaps even when I put the retainer back in. Has anybody seen this or seen the correct part sold anywhere?
1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in.
Sir Searchalot
Sir Searchalot
Have not seen, find a transmission shifter or Ebrake boot from some car or truck from 1940-2010, or.....switch to underdash lever E-brake. Plenty of parts for that. Abandon driveshaft style and cover hole with sheet metal.
guumbah #658796 07/01/2010 10:21 AM
I'm in the same boat, guumbah. I've looked for a stock-style replacement, too - though I didn't look *super* hard. I also got the foam donut from a vendor; didn't do a lot of good on its own.
If I find one somewhere, I'll drop you a line.
My 56 is far from show quality, so I'm just going to keep my eyes open for something that would work at junkyards and such. The parking brake lever has a pretty long throw, though.
1956 Chevy 3600 Dually
Thanks. I'll do the same. I may take a variation on the above suggestion (I LIKE my parking brake the way it is!!) and expand the little frame with some sheet metal welded in, or fab a new one, and see if I can make the '53 boot work. I'll let you know. That donut thingy sucks!
Sir Searchalot
Sir Searchalot
Check out all years of VW's. They had bumper "grommets" that are rubber and are long slotted, but I don't know their size. I Just remember that much. I believe the bumper bracket went thru them and the grommets went against the body? They are on Ebay brand new for $2. Maybe you can bond them with 3M rubber seal, onto another suitable piece of rubber and make something that looks right? Don't know.
