0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, I had a local pin-striper painted my emblems. They came out terrible..Can someone tell me what happened around the numbers and letters ? Why did the paint blister? Not impressed with this guys work...need to know what to seay when I confront him... Thanks!
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | contamination, maybe left on imperfectly cleaned emblems, maybe from polish you or the chromer used, or something in the paint, could just be entrained air from using a brush - should have been visible before the paint dried ... the wrinkling next to the 3100 looks like recoating before the firt coat had enough flash time .... pretty messy on the tops of the letters/numbers too for a "pro" I'd clean it all off with the right solvent and do it myself with nail polish  Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Bill, Yup pretty upset about this. Bad luck on my choices of people to do the work all around. I think I will just do it myself What happened was they guy painted the fender emblems black. When I showed up to get them and told him this he painted them within 45 minutes the correct red. He gave them to me still wet. Wife was there so I did not want to make a big deal... But will now.
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | ahh, likely then a reaction between the 2 coats, maybe even different brands of paint, and no doubt he laid the red on thick to cover with one coat, not a good practice
Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Jon, bottom line is YOU don't have to be an expert and know all of the technical terms. It's HIS responsibility to provide you with professional results unless you specify otherwise. Just take it back & tell him the lifted paint is not acceptable.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Did you tell him to paint them red to start with? If so, make him do them over. They guy's got a bad attitude which happens all too often when crooks have more work than they deserve.
If you didn't specify color he should have asked.
Any one hand that kind of mess over to a customer doesn't deserve your money. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hey guys, Yeah I felt he rushed the job and just free handed without taping off the letters or doing a good enough job. I did send him a photo of what the fender emblems looked like and yes he did know they were red.
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | In that case just take it back and tell him you're not satisfied. Point out the problems and see what he says. If he's an honest guy he'll do it over... and do it right but I wouldn't expect him to tape off anything. He's a pin striper and good enough with a brush.
You could have done it better if you just spray them with red enamel and wipe it off the raised stuff with a thinner dampened rag. It's simple and if you screw it up it takes all of ten minutes to wash it off and do it again. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | The wrinkling I see is usually the result when the reducer/thinner in the top coat reacts with the paint under it.
I got that same result once using rustoleum in a rattle can over rustoleum that came from a qt. can.
Take all the paint off and start over.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Terrible job taping of the surfaces to protect. Looks like the solvent from the first coat was not allowed to dry or flash and he just laid the second and subsequent coats on thick, trapping the solvent from the first and resulting in the lift or rippling effect you have. I believe this was already posted by another member, so get your $ back and try it yourself if you want, can't do much worse than that quality wise. Who knows, with a little patience, you could be a "Foose" in the making. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I got that same crinkly effect when I sanded a chip out of my valve covers and wiped it with PRE, then sprayed it too soon. Or it wasn't compatible.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have painted these type parts with testors enamel paint that we used on our model cars, planes, and boats - and got a better look.
But then, I like work trucks not trailer queens.
It is what you want that counts
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Gave the guy the emblems back. I told him I expect a better job. I hope he got the message. I will post what happens next! Thanks all... 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Good luck seeing those again within a year. I hope you gave him a deadline.
Pick up a quart of enamel from the hardware store and a couple of artist brushes and do it your self. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Green, Yes it getting to that point. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | If you don't hear something by this time next week, just show up and see where he is with your project. Might have to as we say down South, stomp a mudhole in his rearend and walk it dry. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hank, HA! Sounds good to me. Trust me I am a birddog when it comes to my stuff. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Me too Unkl, I follow the Ronald Reagan doctrine, "Trust but verify".
Hank | | | | | Joined: Oct 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 83 | The red "wrinkled". Wrinkling is caused by too many top coats to soon over un-flashed paint. It looks a lot like a fingerprint... Go get a book on Automotive Painting it will cover (or should) trouble shooting paint problems. This was very amaturish for a guy taking money for work.Paint needs to "flash off" between coats or it will have a "orange peel" texture, wrinkling is extream orange peel. Wrinkling can also be caused by soft (not yet fully dried or cured)incompatable undercoats. This guy shot the red over the black before it was fully dry. He should have removed the black, made sure the surface was properly prepared and applied the right stuff, WAITED till it was "cured to service" and THEN called you.
1999 GMC Yukon 1957 GMC 100 Panel
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hey Doug, Took it back to the guy and told him he would need to do it over 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
