5 members (mick53, Grandpa C., lumbersawyer, Nick in Manitou, Wally / Montana), 127 guests, and 3 robots.
Topics128,264
Posts1,058,357
Members48,485
#657702 06/27/2010 10:55 AM
Looking for a little advice. I picked up an old Saginaw 4 speed because my original one broke a tooth on the main cluster gear the first day I put the truck on the road. yea bummer. anyhow this 2nd trans went in real easy and shifts beautifully but makes a LOT of whining noise in 1st , 2nd, and 3rd. It's quiet in 4th. The noise stops when you push in the cluthch. The throwout bearing is OK. Any ideas on what causes this?
neswes #657720 06/27/2010 2:26 PM
Riding in the Passing Lane
The front input shaft bearing is probably rough. Pull the trans & remove the retainer. Shine a light in the bearing & slowly turn the shaft. Look for any scoring or pitting on the inner & outer races & the balls. The bearing can be replaced without tearing down the trans.
1972 Chevy c10 Cheyenne Super
It's also possible the needle bearings on the cluster gear are bad. In 4th. gear, there's little to no load on the cluster gear, and the niose of a bad bearing is minimized. Time for a rebuild, before you chew up another bunch of expensive gears. A bearing and seal kit isn't that costly.
thanks for the advice I'll tear into it a little next week. Between the 2 transmissions I should be able salvage enough good parts for one.
