0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65752 09/15/2006 12:39 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | Ok, Eldbrock 4 barrel carb. on a 350 chevy engine,stock points dist., do I hook up the dist. vacumn line to the pass. side (timed) port or the driverside,( vacumn all the time)port  ??? Help,Thanks | | |
#65753 09/15/2006 1:23 AM | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | passenger side- you only want your distributor to advance when the engine is sucking in more air, not at idle. | | |
#65754 09/15/2006 3:16 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | Wrench, Thank You!!! Thank YOU!!! Thank You !!! That's what I thought but I wasn't sure. Thanks for the help. Hotrod | | |
#65755 09/15/2006 10:02 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I prefer to use the vacuum at idle port if possible. If it surges on idle or barely above or if its an auto trans & drops down a lot when you put it in gear than I go to the ported vacuum side. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
