6 members (Youngin' Tut 59, DadsFirstPickup, asilverblazer, Gray_Ghost, Otto Skorzeny, 51sub), 54 guests, and 3 robots.
Topics128,180
Posts1,057,146
Members48,463
Ok, Eldbrock 4 barrel carb. on a 350 chevy engine,stock points dist., do I hook up the dist. vacumn line to the pass. side (timed) port or the driverside,( vacumn all the time)port frown ??? Help,Thanks
passenger side- you only want your distributor to advance when the engine is sucking in more air, not at idle.
Wrench, Thank You!!! Thank YOU!!! Thank You !!! That's what I thought but I wasn't sure.
Thanks for the help. Hotrod
Riding in the Passing Lane
I prefer to use the vacuum at idle port if possible. If it surges on idle or barely above or if its an auto trans & drops down a lot when you put it in gear than I go to the ported vacuum side.
1972 Chevy c10 Cheyenne Super
