| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Does anyone know if vacuum wiper motors were made with different strokes? I’m trying to use a stock vacuum wiper system on my ’41. My problem seems to be that my wiper motor stroke is too long. The truck has a stock height windshield. The wiper blade hits both the windshield center divider and the top of the windshield frame. I have tried the motor that came with the truck and one off of e Bay with similar results. I have also tried various length arms and blades, but the results are always the same the stroke is too long. | | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Hi Kip´s41, when I was solving the same situation than you, I used three differents kinds of vacuum wiper motor to adapt them to work. Too short strokes, too long strokes, poor power, etc. At the end, tired and frustrated, bought the electric one on classic parts and my problem ends, of course, after expent much more money and time. My advise: use the specific motor for your truck, whatever electric or vacuum. My truck is 52 chevy 3/4ton. Alfonso | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks for the suggestion Alfonso.
I have since found out that these wiper motors were made with strokes of 89, 107,117 & 126 degrees so I’m fairly sure I have one that has a longer stroke that required.
