Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Greg_H, 68ironhead, Peggy M, TUTS 59, Bill Hanlon, Hambone), 68 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#657245 06/25/2010 1:43 PM
A local paper has advertised a "HydraMatic transmission that fits a Chevy 235 & 261" for sale. It got me to wondering if Chevy ever used a HydraMatic in an AD or TF pickup. I understand they used it in larger trucks but I don't recall ever seeing one in a light duty except for GMC. Please commment.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Yes, Chevy used a limited number of HydraMatic transmissions in pickups. I think they started doing that a year or two after GMC did. There are a couple of distinctive differences in the Hydro that identifies it, such as a rectangular sheet metal housing on the side of the case where the shift lever and throttle linkage fits. That's in addition to the regular sump pan on the bottom. There's also only about half of the fluid coupling covered by the bellhousing, making room for adapter rings to fit various engines, not all of them GM. Lincoln, Nash, and a few others also bought the transmission for use in their vehicles.
3B Offline
Hy 53moneypit, yes the Hydramatic was available in light duty ADs and TFs I believe starting in 53 or 54. My first Hydramatic truck was a 57 with a V8. I have an engine and transmission from a 54 panel, that was Hydramatic equipped. The Hydramatic [dual range] continued to be used up to 62, the last year for the 235/261 engine, hope that helps.
3B #657273 06/25/2010 3:54 PM
GMC first had a non-military-truck Hydra-Matic option in 1953 small trucks, and a variety of Hydra-Matic options for most larger trucks in 1954. Chevrolet trucks had a Hydra-Matic option in 1/2 to 1 ton trucks in 1954.
The engine and Hydra-Matic transmission were matched at the factory (and marked as being matched) but people have reported using Chevrolet hydra-matics with non-original 235/261 engines (same with GMC hydra-matics being used with non-original 228/248/270 GMC engines).
I have a friend with a '54 3600 that is a Hydra-Matic. Nice driving original appearing truck.
