9 members (klhansen, electors, cmayna, JW51, Tronman, tclederman, Otto Skorzeny, Bill Hanlon, Peggy M), 56 guests, and 3 robots.
Topics128,041
Posts1,055,490
Members48,424
#6570 01/17/2005 2:49 AM
Junior Member
Junior Member
Stovebold, appreciate your expertise on the mystery slotted head bolt used for oiling a pre '58 head on a later block.Any ideas on why my 261 ('62 block),('57 head) that is a fresh rebuild and running in its frame without a bolt like that? When I took my engine apart and delivered the block and head to the machinist, he said it looked like both pieces were original. Is it possible the '57 head was a modified casting and just wound up with my engine at original assembly? You also mention dual Holley-Webers for the 261 I just picked up. They won't fit on the Edelbrock manifold thay came with the engine, will they? The manifold has spacing for a type 2 carb. Thanks everyone.
#6571 01/26/2005 12:33 PM
57 head hu? Well I learn a bit every day grin
Does it have the oil line under the side cover?
I got a dual Weber/Holley setup on a Offy intake
Got my adaptors from Tom Langdon and they may fit your intake also. Talk to Tom on details, he`s the guy who also may solve the bolt mystery.
http://www.stoveboltengineco.com/index2.htm
have fun and many greetings from sunny southern Germany, Frank
#6572 01/27/2005 2:37 AM
From 1938-62, only two head bolt part numbers are listed for 216, 235 and 261. Long and short except for a special drilled bolt, used when a 59-62 block is used with earlier top end* to reduce the oil flow to the rockers.
Note: Use with drilled bolt
Plug # 37 64 579
Install in block oil port near right center head bolt.
This plug blocked the original oil path and sent it through the drilled head bolt
* The cylinder head did not change but the rockers did.
Without this plug and special bolt you will get to much oil to the top end.
My Blog
