| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 43 Junior Member | | Junior Member Joined: Jan 2004 Posts: 43 | Stovebold, appreciate your expertise on the mystery slotted head bolt used for oiling a pre '58 head on a later block.Any ideas on why my 261 ('62 block),('57 head) that is a fresh rebuild and running in its frame without a bolt like that? When I took my engine apart and delivered the block and head to the machinist, he said it looked like both pieces were original. Is it possible the '57 head was a modified casting and just wound up with my engine at original assembly? You also mention dual Holley-Webers for the 261 I just picked up. They won't fit on the Edelbrock manifold thay came with the engine, will they? The manifold has spacing for a type 2 carb. Thanks everyone. | | |
#6571 01/26/2005 12:33 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | 57 head hu? Well I learn a bit every day Does it have the oil line under the side cover? I got a dual Weber/Holley setup on a Offy intake Got my adaptors from Tom Langdon and they may fit your intake also. Talk to Tom on details, he`s the guy who also may solve the bolt mystery. http://www.stoveboltengineco.com/index2.htm have fun and many greetings from sunny southern Germany, Frank | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | From 1938-62, only two head bolt part numbers are listed for 216, 235 and 261. Long and short except for a special drilled bolt, used when a 59-62 block is used with earlier top end* to reduce the oil flow to the rockers.
Note: Use with drilled bolt Plug # 37 64 579 Install in block oil port near right center head bolt.
This plug blocked the original oil path and sent it through the drilled head bolt
* The cylinder head did not change but the rockers did.
Without this plug and special bolt you will get to much oil to the top end.
See the USA in your vintage Chevrolet! My Blog | | |
