0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#65654 09/13/2006 5:35 PM
Can anyone tell me with certinty that there is a difference between a 235 powerglide head and a 235 truck head? I have a 51, 235 p/g engine that keeps breaking intake rocker arms. The head casting # 3835499 is suppose to be a 50-52, 235 head. I have found two 1 inch water holes in the head but not in block or head gasket. Maybe I have the wrong head for a p/g engine. That head gets darn hot and really smokes out of the valve cover after shutdown.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#65655 09/13/2006 7:00 PM
The 1954 chev parts book says "1950-52 All with 235", Part #3835908
My Blog
#65656 09/13/2006 8:07 PM
I can't answer your question. But I was wondering if you have a 235 splash engine, or a 235 full oil engine. Those engines are actually really different, and if you are mixing the head and block from the 2 different engine types that might be your problem.
I believe you could also get the pressed steel rockers and put them in instead of the cast iron rockers. It should be a direct swap.
Sorry for being vague, I'm a gmc guy and never really got into any of the chevy 6s.
#65657 09/13/2006 8:23 PM
Pressed steel rockers? I don't think I have ever seen those things. Any pictures!
Stuart
#65658 09/13/2006 9:17 PM
1950-52 passenger 235 PG. Block casting 3835692
is listed with head 3835499 or 3835909.
1950-52 truck uses the same head 3835499 with a different block.
The valve spring for a PG is different.
1938-51 All (exc. PG) 2 1/8 O.L. x 31/32 I.D.
1950-51 Pass. w/ PG (painted w/ aluminum - L.H. coil.
-Tom
1950 Chevy 3100 w/ 1956 235
#65659 09/18/2006 3:55 AM
It sounds like my head is correct. The casting #is 3835499. Although Inliners call it a 216 head. I've been told, no way a 216 head will fit a 235. The bolt pattern is differnt. The engine 3692703 is listed as a 50-51, 235 p/g. This is a low pressure dipper engine. I'll check the spring coil. Thx guys.
1952 Chevy 1/2-Ton
