0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65654 09/13/2006 5:35 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Can anyone tell me with certinty that there is a difference between a 235 powerglide head and a 235 truck head? I have a 51, 235 p/g engine that keeps breaking intake rocker arms. The head casting # 3835499 is suppose to be a 50-52, 235 head. I have found two 1 inch water holes in the head but not in block or head gasket. Maybe I have the wrong head for a p/g engine. That head gets darn hot and really smokes out of the valve cover after shutdown.
Glenn, | | |
#65655 09/13/2006 7:00 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 1954 chev parts book says "1950-52 All with 235", Part #3835908
See the USA in your vintage Chevrolet! My Blog | | |
#65656 09/13/2006 8:07 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I can't answer your question. But I was wondering if you have a 235 splash engine, or a 235 full oil engine. Those engines are actually really different, and if you are mixing the head and block from the 2 different engine types that might be your problem.
I believe you could also get the pressed steel rockers and put them in instead of the cast iron rockers. It should be a direct swap.
Sorry for being vague, I'm a gmc guy and never really got into any of the chevy 6s. | | |
#65657 09/13/2006 8:23 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Pressed steel rockers? I don't think I have ever seen those things. Any pictures!
Stuart | | |
#65658 09/13/2006 9:17 PM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | 1950-52 passenger 235 PG. Block casting 3835692 is listed with head 3835499 or 3835909.
1950-52 truck uses the same head 3835499 with a different block.
The valve spring for a PG is different. 1938-51 All (exc. PG) 2 1/8 O.L. x 31/32 I.D. 1950-51 Pass. w/ PG (painted w/ aluminum - L.H. coil.
-Tom
1950 Chevy 3100 w/ 1956 235
#65659 09/18/2006 3:55 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | It sounds like my head is correct. The casting #is 3835499. Although Inliners call it a 216 head. I've been told, no way a 216 head will fit a 235. The bolt pattern is differnt. The engine 3692703 is listed as a 50-51, 235 p/g. This is a low pressure dipper engine. I'll check the spring coil. Thx guys. | | |
