1 members (JW51), 151 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#656215 06/20/2010 9:57 PM
Hey everybody, asking for 'what would you do?' input. I'm working on a 49' 3600 that still has the original split rims. I'm planning on keeping the truck as stock as possible but unsure of hanging on those time bombs.....I've heard alot of bad about them. Not to mention most shops won't touch them anymore. If I were to swap out them out....recomendations that would stay as close as possible to a stock appearance? They are 8 lug too.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Try and find something that is the same, over very close, but non-split rims. I've heard the horror stories too, and it seems much too chancy to play dice with.
1959 Chevrolet 3100 Stepside Apache
"Ignorance is bliss. Here's a history book."
There is a lot of information in the search area about wheels and that is where is where I suggest you look first. Use the word wheels as your primary search and I think you'll be surprised as there are always a lot of questions since the "split rim" designation is very misunderstood. One of our contributors (Grigg) is very knowledgable about wheels and has written a Tech Article feature which you'll find listed on the homepage.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
For a 3/4 ton try some 16" tubeless wheels off newer (than your) Chevy, ford, and Dodge trucks and vans.
I don't have a direct answer, but see what you find that fits over your brake drums and clears everything. Many of these wheels have similar looking centers to your original wheels, some even with hubcap clips if you find old enough ones.
•1952 Chevrolet 3800 pickup
---All pictures---
