| | | Forums66 Topics128,193 Posts1,057,360 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | My front fenders are in fair shape but the bracket that runs from the top to the bottom where it bolts to the rear bottom has rusted just about completely away. I ordered the ones from LMC for both sides but do they go all the way to the top. What have you guys done? Its a 58 GMC 1/2 ton short bed. Thanks Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | don't know about LMCs, but all I've seen of those pieces go about 1/2 the way up, enough to do a fix of that attaching point - make sure you treat the back side against rust or it won't last long, I spray them with high zinc weld-thru primer
Bill | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I got those brackets from LMC today and you're right, they only go about halfway up the fender. Guess I'll have to some fabricating on one side. I found a fender for a 57 Chevy and paid $25 for it and it had a top half of the bracket and a lower patch panel on it. There is a slight difference in the shape but I think I can make it work. Larry
