5 members (TPR57C, Bill Hanlon, Samantha, TooMany2count, 1 invisible), 149 guests, and 3 robots.
Topics128,186
Posts1,057,315
Members48,469
My front fenders are in fair shape but the bracket that runs from the top to the bottom where it bolts to the rear bottom has rusted just about completely away. I ordered the ones from LMC for both sides but do they go all the way to the top. What have you guys done? Its a 58 GMC 1/2 ton short bed.
Larry
58 gmc 100 with 350 sbc
don't know about LMCs, but all I've seen of those pieces go about 1/2 the way up, enough to do a fix of that attaching point - make sure you treat the back side against rust or it won't last long, I spray them with high zinc weld-thru primer
I got those brackets from LMC today and you're right, they only go about halfway up the fender. Guess I'll have to some fabricating on one side. I found a fender for a 57 Chevy and paid $25 for it and it had a top half of the bracket and a lower patch panel on it. There is a slight difference in the shape but I think I can make it work.
Larry
