0 members (),
51
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 6 New Guy | | New Guy Joined: Jan 2007 Posts: 6 | Does anyone know or can tell me how the radiator support is connected to the frame? The support I have ,both sides that bolt down are on the inside of the frame. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | have you modified the frame? sure you have the right core support? there should be 2 angled brackets at the bottom with large-ish holes [rubber fits inside with a ferrule to shim the bolt] that line up with 2 brackets on the frame .... good pic in the assembly manual
Bill | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | took some pics for you pic1 - pic2 - hard to get good shots in there, but yeah, the frame brackets are slightly inset, yours must be missing  the PO prolly thought it would be sub framed and get some fancy cross flow rad, I've seen frames with those brackets cut off Bill | | | | | Joined: Jan 2007 Posts: 6 New Guy | | New Guy Joined: Jan 2007 Posts: 6 | Thank You for help and pics. You are right the brackets are missing, so I will make my own. | | |
