1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 21 New Guy | | New Guy Joined: Feb 2007 Posts: 21 | Has any body paid close attention to taper wheel bearing kits that come from several suppliers for the 47 to 53 truck? Where were the bearings made? Only answers I get(from the three suppliers I called) is "I think they are made in Taiwan". I have enough experience with bearings to know I do not want Taiwan bearings. That is like the cheap crap that comes on low end trailer axles when buying a new trailer. Most guys, that really need the trailer, immediately take them out and get good Timken bearings. Is there a number on the bearing? I am thinking about doing the machine work myself and sizing new Timken bearings if Taiwan junk is all that is available. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If the ball bearings are in good shape I see no reason to change. Cleaned and properly greased they will give many years of good service. You might check with the Fiiling Station they used to have a good selection of new and nos parts. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I believe these are the correct numbers and all may be National. I bought mine from Classic Parts and later discovered this information. A quick check at your local FLAPS should verify.
Inner: 909052R Outer: 909067R Seal: National 6064 | | | | | Joined: Feb 2007 Posts: 21 New Guy | | New Guy Joined: Feb 2007 Posts: 21 | Yeah I don't know why the ball bearings wouldn't be serviceable. I mean they worked for years. What is all the hype about changing to taper roller bearings just because of disc brakes? Why wouldn't the other bearings take it? I did change to disc brakes six lug. I plan to drive her a great deal. Czechman, are those part numbers for ball bearings or rollers? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Czechman, are those part numbers for ball bearings or rollers? I don't know for sure but I believe they are for the roller bearings. It's been years since I found that information posted here. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The six-lug disk kits use the original hub and therefore the original ball bearings can be used.
The five-lug kits use an integrated hub/rotor that was designed to use roller bearings.
If you are going with a six-lug kit and your bearings are serviceable there would be no reason to replace them. Going with a five-lug kit you may have no choice but to convert to rollers.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
