1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#655388 06/17/2010 4:28 AM
I was wondering if anyone can tell me what this hole is for? I have a 65 C10 and on the drivers side on the floor pan towards the rear there is a factory made hole about the size of a quarter and there is a factory made v cut channel that runs from right below the hole to the the top of the rocker panel. It almost looks like a handle would rest in the channel and go through the hole to access something under the cab. Thanks...
It is for your tail light wires My 61 has a cover on top
Thanks Big T. So the wires would come down the firewall and go under the sill plate? or what?
yup. up the sill plate. there should have been a cover with one screw that mounts over top of that hole to give it a cleaner look and protect the plug. its about 4 or 5 inches
Dual saddle tanks had a transfer valve mounted in this location. I have several trucks with them, although most have had the tanks removed. I have a half-dozen of the transfer valves, removed from donor cabs.
