| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 12 New Guy | | New Guy Joined: Jan 2010 Posts: 12 | I was wondering if anyone can tell me what this hole is for? I have a 65 C10 and on the drivers side on the floor pan towards the rear there is a factory made hole about the size of a quarter and there is a factory made v cut channel that runs from right below the hole to the the top of the rocker panel. It almost looks like a handle would rest in the channel and go through the hole to access something under the cab. Thanks...
| | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | It is for your tail light wires My 61 has a cover on top | | | | | Joined: Jan 2010 Posts: 12 New Guy | | New Guy Joined: Jan 2010 Posts: 12 | Thanks Big T. So the wires would come down the firewall and go under the sill plate? or what? | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | yup. up the sill plate. there should have been a cover with one screw that mounts over top of that hole to give it a cleaner look and protect the plug. its about 4 or 5 inches | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Dual saddle tanks had a transfer valve mounted in this location. I have several trucks with them, although most have had the tanks removed. I have a half-dozen of the transfer valves, removed from donor cabs. | | |
