4 members (Maybellene, J Lucas, Otto Skorzeny, Leo), 66 guests, and 3 robots.
Topics128,057
Posts1,055,808
#655355 06/17/2010 2:10 AM
I want to rebuild my carb. I get two different part numbers,2g/2gv or 2g/2gc it's a Rochester. any help would great. was'nt sure if I should post this some where else. thanks Brett
Riding in the Passing Lane
The best way to ID the carb is the brass tag that is/was under one of the cover screws. Most of the time it is gone by know. The 2G is manual choke & the 2GC is auto choke. I don't know where the 2GV comes in.
1972 Chevy c10 Cheyenne Super
I think the V means the bowl is vented. It shouldn't make any difference in a replacement or parts kit.
Fred
The kit that I bought from napa covers all the 2g carbs. there was about 4 different sets of gaskets in there.
Thanks for the info. I was thinking of buying both kits as I have'nt an I.D. tag and can't find a #. It's a 283 v8 with a three on the tree converted to floor shift, as far as I can tell.Just picked her up in may. Brett
cool
v
is for victory.
smile
well not really.
but i think it is for vacuum.
check out this site and find the manual for rochester 2-jet models 2G 2GC 2GV
rochester bulletin 9D-3
its freeeeeee
www.oldcarmanualproject.com/carbs/rochester/2-jet/manual/index.html
if the above link doesnt work ... or you cant figure out exactly how to get to the exact page you want..... do this-
google rochester 2-jet carburetor manual
click on the first listing
smile
hth
paul
See the write up from The Carburetor Doctor website: http://www.carburetor.ca/carbs/tech/Rochester/TwoJet-index.html
Pete
cool
dr.carbs note that the choke is now located outside the carb body ( for the disignation 'V') is correct - but the mechanism that drives it is Vacuum .
smile
paul
Thanks for the info. I'll take a look. Brett
