1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#652824 06/06/2010 8:30 PM
any one know what this is? http://i831.photobucket.com/albums/zz233/Toste_bucket/66%20chevy%20C-30/0606100654a.jpg http://i831.photobucket.com/albums/zz233/Toste_bucket/66%20chevy%20C-30/0606100654.jpg its at the back of the valley. it lines up with the hole in the block ( i think the hole is where the distributors used to be put in?) what is it, what does it do, do i need it and can i get rid of it if i dont? thats my general approach to autos. lol. not always the best way, but ill admit that it makes me learn from my mistakes!
66' Chevy C-30 Rat
Riding in the Passing Lane
That is a deflector for the crankcase ventilation system. There is a road draft tube going in the hole by the dist. This system was used before the PCV system was put in in 1963. I suppose you could block it off & use a PCV valve.
1972 Chevy c10 Cheyenne Super
hey thanks! i think ill just leave it be unless there is a real reason to change it. i prefer the breather caps without the pcv valves, think they detract from the look. do i need to clean it, or. . .i guess a better thing is to ask about the maintenance on it. how do i take care of it?
66' Chevy C-30 Rat
You should pull it & clean it. You must have the road draft tube in the hole by the dist. You have to have a breather cap on the oil filler tube in the front of the manifold.
good stuff man, thanks!
66' Chevy C-30 Rat
i took a look at mines and it had a hose with a pvc valve going to the carb is that ok. No draft tube
