| | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That is a deflector for the crankcase ventilation system. There is a road draft tube going in the hole by the dist. This system was used before the PCV system was put in in 1963. I suppose you could block it off & use a PCV valve. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | hey thanks! i think ill just leave it be unless there is a real reason to change it. i prefer the breather caps without the pcv valves, think they detract from the look. do i need to clean it, or. . .i guess a better thing is to ask about the maintenance on it. how do i take care of it?
66' Chevy C-30 Rat
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You should pull it & clean it. You must have the road draft tube in the hole by the dist. You have to have a breather cap on the oil filler tube in the front of the manifold. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 |
66' Chevy C-30 Rat
| | | | | Joined: May 2010 Posts: 32 New Guy | | New Guy Joined: May 2010 Posts: 32 | i took a look at mines and it had a hose with a pvc valve going to the carb is that ok. No draft tube
