2 members (2-Ton, farmallb),
67
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks like a stock 3800 driveline to me. Depending on what differential you're using, you may be able to directly swap without altering the driveshaft, other than perhaps a dual size U joint.
Bill Burmeister | | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | good news if it is. I was not happy with the alternatives for swapping out this diff/trans combo and this will make things much easier.
Any knowledge on what diff. will swap in without cutting? I plan on switching all 4 wheels to a standard 5 bolt.
...don't tell me to "look in the archives"... I have and I didn't find what I was looking for... that's why I'm asking ><
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | If you are planning on switching to standard 5 bolt, then it does not matter what diff. you have now because you will have a different diff. when you are done with your swap. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | fiveoh...are you thinking that you could swap to a 1/2 ton AD diff to get the five lugs? No you cannot. As Lonny points out it really doesn't matter what you have now and the driveline will be different anyway up to and possibly including the transmission. You'll need to get rid of the front shaft too and hqve a custom shaft made. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not necessarily. If the original trans is being used, the rear U joint can be adapted to whatever yoke is on the replacement rearend using a dual size u joint. Did just that once on a '49 3800 that we had swapped a Dana 60 out of a 3/4 ton Dodge van into. The Van yoke took a smaller cap size, so we installed a Spicer u joint with dual cap sizes. Worked just fine. Now, without being 100% sure of what direction fiveoh is going, it's hard to say what diff should be used or what to do with the driveshaft. I will say that you're going to looking at a front axle swap, too, as none of the aftermarket 5 lug parts will fit the 1 ton axle.
Bill Burmeister | | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | cool...thanks guys.
The plan is now to pull the AD design diff completely. I'll take the rear drive shaft to have it cut and a matching yoke put on if the new u-joint combination can't be found.
