| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | any one know if these will work in a 1962-63 327 block? http://www.summitracing.com/parts/NAL-12499225/it says they fit a 323, 325, 350; im thinking since a 327 is in between that range they would work. thanks
66' Chevy C-30 Rat
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Summit spec's say these are for an LS engine - 1999 & up. I'd call Summit and confirm before ordering | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Nope- - - - -the lifter valley is set up differently on the pre-roller engines, and there's no way to make the later-model lifters work in the 327. Jerry
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | There are hydraulic roller kits that allow you to retrofit non roller SBC blocks with rollers. Pretty pricy for the kits. Search the Summit site for hydraulic rollers and you will find them. | | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | glad i asked before i ordered! thanks guys.
66' Chevy C-30 Rat
