3 members (Paul_WNC, thekid1950, TUTS 59), 23 guests, and 5 robots.
Topics128,012
Posts1,055,320
Members48,419
#654878 06/15/2010 5:14 AM
any one know if these will work in a 1962-63 327 block? http://www.summitracing.com/parts/NAL-12499225/
it says they fit a 323, 325, 350; im thinking since a 327 is in between that range they would work. thanks
66' Chevy C-30 Rat
Summit spec's say these are for an LS engine - 1999 & up.
I'd call Summit and confirm before ordering
1940 Chevy KC 1/2-Ton
H Online: Content
Nope- - - - -the lifter valley is set up differently on the pre-roller engines, and there's no way to make the later-model lifters work in the 327.
BrianToste #655156 06/16/2010 12:28 PM
There are hydraulic roller kits that allow you to retrofit non roller SBC blocks with rollers. Pretty pricy for the kits. Search the Summit site for hydraulic rollers and you will find them.
SimS #655343 06/17/2010 1:17 AM
glad i asked before i ordered! thanks guys.
66' Chevy C-30 Rat
