3 members (Otto Skorzeny, gswbbc, joe apple), 165 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#6545 12/04/2003 7:01 AM
52' with a 235. Rochester Carb
I thought Ken's post from 12-1 (hesitation ...) was just what I was lookin for, but nope. Drove home the other night and thought I was running out of gas (1/2 tank). For some reason I pulled out the choke, it came back but with higher RPMs. Pushed the choke in and it died.
Got any thoughts?
Thanks ahead of time, jeff
#6546 12/04/2003 7:06 PM
Closing off the top of the carb (choke) does increase vacuum. I would check for vacuum leaks or fuel delivery problems, clogged fuel filter, fuel pump etc.
54 3100 with 235
62 flatbed dump C60 with 261
#6547 12/04/2003 8:32 PM
Sounds like the main jet/orifice may be partially plugged. Closing the choke helps "suck" more fuel through the main circuit (it is actually atmospheric pressure that pushes the fuel to an area of lower pressure).
#6548 12/04/2003 8:36 PM
Since it's a leakmeister Rochester, check the throttle body shaft for wear, too. Major source for vacuum leaks.
Fred
52 3600
69 C-10
#6549 12/05/2003 1:12 AM
k10 Offline
Have you checked the heat riser operation?
#6550 12/05/2003 1:35 AM
All good points and I would like to add ,,, Look for vacuum leaks at the intake to head and around the base of the carb.
#6551 12/06/2003 7:19 AM
Thanks Guys,
As usual, the responses are "always" quality. And, in checking all of the above, I've ordered a rebuild kit from NAPA. Can't hurt.
I should have this solved over the weekend.
Thank you all ahead of time, jeff
P.S. For all you Southern Californers, don't forget Pomona this Sunday. An remember to pack your flashlight-still dark at 5;30am.
